Intensity Pro - Dropped/Lagged Recording
Brett Plank
on Oct 15, 2009 at 1:32:15 am
I've had my Intensity Pro for almost a year now, and have been capturing 720p Xbox 360 Gameplay for the same amount of time without any problems. Up until this month, I haven't updated any of my drivers or software for Blackmagic. But as of last week (before I updated anything), it started to lag, (Virtual Dub says that there are NO dropped frames, yet Media Express says there are dropped frames.) but just "lag" when I record. It happens in VirtualDub and Media Express. Note I have been able to capture 720p flawlessly with Virtual Dub for over a year, until now.
So I finally updated my Intensity Driver and Software, downloaded the newest Media Express (which is terrible, as it doesn't fit most monitors) and reinstalled the actual card. I can still see the picture and play fine on vDub and Media Express, yet when I record this "lagging" issue again occurs. Here is a video of what I'm experiencing.
Anyone?
Margus Voll
Re: Intensity Pro - Dropped/Lagged Recording
on Oct 15, 2009 at 7:05:21 am
Hi.
Have you tested HDD speed on which you record.
How much free do you have ?
Margus
http://iconstudios.eu
Brett Plank
on Oct 16, 2009 at 2:11:12 am
No I have not. How should I do that?
I have 75GB free on my C-drive, which I record to.
And the thing is, everything was working fine before, no dropped frames at all.
Margus Voll
on Oct 16, 2009 at 5:01:53 am
Hi.
How big is the drive ?
Generally recording to drive c is big no no. You should have separate drive. Better if 2 or more drives in raid.
Start BM disk speed test and see how fast is your drive also.
What compression did you use if eny?
Margus
Brett Plank
on Oct 18, 2009 at 2:00:01 am
Well I had a 250 GB Hard drive, but that stopped working. I'm gonna get a bigger Hard drive.
How do I perform a BM Disk Speed Test?
And I use Compressed Motion JPEG.
Margus Voll
on Oct 19, 2009 at 3:31:59 pm
Hi.
If you installed BM drivers you got also BM disk speed test.
Just find it and start it and voila.
Margus
