HD Extreme 3 - HD to SD Down Scale
Bill Seville
on Oct 13, 2009 at 5:52:45 am
Have our footage which was shot using the Panasonic Varicam 2700 (P2) at 720p at 24fps. I may need to have this footage available in both HD and SD so I thought I would try downscaling with the BMD card. We have the HD Extreme 3 (7.3.2).
I have contacted BMD a couple times about this with no response. Using Premiere CS4 (4.1) and thought the process was:
-Use BMD Varicam 720p 23.976 preset in Premiere
-In BMD control Panel, under Processing - select output processing - HD to SD Center Cut 4:3 (for example)
-Hit save
-Go back to Premiere and ???
Sorry but never used before and I thought we we purchased the card, I was told it can do this. Thanks all...just trying to end up with the best footage possible both ways.
