Want to buy used BMD DeckLink SP is it worth?
Marcin Mikołajczyk
on Oct 7, 2009 at 8:20:01 am
like in topic, i have MacPro QuadCore 2x2.8 and i want to buy video card mainly for monitoring picture from Apple's Color.
I don't want to spend too much money for this so i was wandering that simple DeckLink SP which i can get for about 200$ will be enough. I've found in forums that those cards is not working with new MacPro's, is it true?
I need to have analog output so Intensity card is not the solution.
Any other ideas? Or I need to buy for example DeckLink Studio or Kona LHe?
Thanks in advance
MP 2x3.0 Ghz
FCS 3
Poland
Kristian Lam
Re: Want to buy used BMD DeckLink SP is it worth?
on Oct 11, 2009 at 11:26:25 pm
Hi Marcin,
If you have a newish Mac Pro, chances are it will have PCI Express slots. You'll need to make sure the DeckLink SP you're getting has PCI Express slots as we make a version for PCI slots as well.
regards
Kristian Lam
Blackmagic Design
