final cut crashing. please help.
cory tardy
on Oct 4, 2009 at 2:27:02 pm
I have a 8 core 10.6.1 running snow leopard with a decklink extreme hd 3 card. quite often when i try to open the log and transfer utility fcp crashes. is this a known problem? are there any fixes? all of my firmware for the card is current as well. thanks!
kaku Ito
Re: final cut crashing. please help.
on Oct 4, 2009 at 5:27:39 pm
Similar issue I have occasionally is that FCP crashes upon booting up.
I found this happens if the volume I had assigned had some problems then it crashes.
So, you might wanna see the scratch volume that you set for the capturing is healthy or not.
Kaku Ito
http://www.musetexsystem.com
http://www.rockrc.net
http://www.brightminds.jp
Kristian Lam
on Oct 5, 2009 at 11:39:51 am
Hi Cory,
Can you specify exactly what version of drivers you're running? Sometimes, you may think it's current but it's actually not the case.
regards
Kristian Lam
Blackmagic Design
