7.2.6 driver on leopard
massimo croce
on Sep 2, 2009 at 9:38:54 am
from Minimum system requirements on the read me file of the 7.2.6 driver:
• Mac OS X 10.6 Snow Leopard and QuickTime 10 or later
• Mac OS X 10.5.7 Leopard and QuickTime 7.6 or later
But when i try to install on leopard I can t do it the installer tell me "This installer requires Mac OS X 10.6 or later to run."
any solution?
Jason Cahapay
Re: 7.2.6 driver on leopard
on Sep 2, 2009 at 12:15:12 pm
Encountered the same issue, it's weird you can't install it when your system meets the minimum requirements.
Here's a workaround,
1. Mount the Decklink_Macintosh_7.2.6.dmg
2. Copy the contents to your desktop.
3. Control+click Decklink Installer 7.2.6 and Show Package Contents.
4. Control+click distribution.plist and open with TextEdit.
5. Edit the ff.
my.target.systemVersion.ProductVersion >= '10.6' to my.target.systemVersion.ProductVersion >= '10.5'
system.version.ProductVersion >= '10.6' to system.version.ProductVersion >= '10.5'
6. Save and install.
Got it working and testing it right now, seems to working fine but I would still advice you to try it at your own risk. =)
massimo croce
on Sep 3, 2009 at 8:37:52 am
OK...
Thanx....
But someone at BMD can resolve this issue?
I have a FCS3 on Leopard and i want to use the drivers...
Grazie
Massimino
Kristian Lam
on Sep 8, 2009 at 3:12:48 am
7.2.6 is Snow Leopard specific. If you're not using Snow Leopard as your OS, then stick to the previous version. The next driver release will work on both Leopard and Snow Leopard.
regards
Kristian Lam
Blackmagic Design
