Intensity Pro+Premiere Pro CS4+Cineform+Color Finesse?
Mikael Couderc
on Aug 29, 2009 at 8:33:46 am
A few questions about The Intensity Pro (any info would be helpful):
-Inside PPCS4, does it work with a Cineform Codec in a Matrox preset? (I know Prospect HD doesn't support it yet, just interested in Codec support)
-Inside PPCS4, using Color Finesse Plug in in Full UI, can I get the card to output a YUV through HDMI, Real Time?
-Anything I should know about potential problems with this setup (PC Core i7 940, Windows 7 X64, PremiereProCS4, Cineform, Color Finesse)
-Is there a better/more compatable BMD card for my requirements?
Any input appreciated! Thanx and good day...
Leo Baker
Re: Intensity Pro+Premiere Pro CS4+Cineform+Color Finesse?
on Aug 29, 2009 at 3:15:08 pm
Hello,
Inside PPCS4, does it work with a Cineform Codec in a Matrox preset? (I know Prospect HD doesn't support it yet, just interested in Codec support).
It only works with a Blackmagic preset output of your timeline.
Not tried this, however component HD and SD out I can preview with After Effects CS3 from Blackmagic preset and using the Eclipse card. Don't know if HDMI is supported, I can't see why not?
For the Cineform capture/playback it would be an AJA card like the Xena LHe, Lhi, 2k.
I been reading on DVINFO on the Cineform forum that support for Blackmagic cardss with timeline monitoring should be avaialble at some stage for cs4 once the real-time engine has been intergrated into cs4, then once thats working then Cineform will be looking at the Blackmagic timeline playback.
Leo
