Multibridge (7.2.1 drivers) with Photoshop CS4 for key/fill
Eric Ameres
on Aug 25, 2009 at 3:00:28 pm
Anyone having luck using a Multibridge pro and the Photoshop export for key/fill? I want to use this to do lower thirds for events. No matter how I do it, it seems to ignore the key/alpha channel and outputs the RGB on both outputs. The images I create do work correctly from the live key application though. I've generated the alpha channel both by hand, and by using the Create Alpha from visible channels action.
Eric.
Eric Ameres
Sr Research Engineer
RPI - Experimental Media and Performing Arts Center (EMPAC)
Eric Ameres
Re: Multibridge (7.2.1 drivers) with Photoshop CS4 for key/fill
on Aug 26, 2009 at 1:33:30 pm
I solved my problem. The Black Magic Livekey app MUST be running for this to work. Once that was running in the background everything works great. Awesome tool!
Eric Ameres
