VideoHub and RS422
Eric Hansen
VideoHub and RS422
on Aug 19, 2009 at 12:22:33 am
i'm about to pre-wire a facility that's going to use the Studio VideoHub. Is there a limit to the length of RS422 cable? we will have HDCAM SR, HDCAM and other decks that will sit in a rack along with the VideoHub. and then use Mac Pros with AJA Kona 3 and LHI cards for control.
also, can you use Cat5 or Cat6 cable for the RS422 runs and just terminate with a 422 connector? is there another recommended cable?
thanks
e
Eric Hansen, The Audio Visual Plumber - http://www.avplumber.com
Bob Zelin
Re: VideoHub and RS422
on Aug 19, 2009 at 2:52:25 am
I use AJA editing products with Blackmagic Videohubs all the time. I use Belden 1583A cable (CAT 5e cable) for RS422 control, and use RJ45-9 pin D adaptors. I put these adaptors on the back of the Videohub, and just "snap in" the RJ45 plugs, instead of screwing in all those 9 pin connectors. I have been using BElden 1583A for 10 years now, and I have NEVER EVER had a failure. I use CAT 5e coupler patch panels as RS422 patch panels, and they work great.
RS422 can be run for a LONG distance - certainly over 300' (probably 1000') without issue.
The Videohub is a world class router, and 100% reliable.
You can get RJ45-9 pin adaptors from http://www.milestek.com
Bob Zelin
