Please help with a xhg1
Carlos Bermudez
on Aug 12, 2009 at 2:07:33 am
I need your help because it fails to capture the output via HDSDI the xhg1. Need someone please tell me the settings to be easy setup to be able to record directly to Apple Porres 1920 x 1080. I've really tried everything and can not. I record in 24F and in the resolution stating that.
Thank you very much!
Kristian Lam
Re: Please help with a xhg1
on Aug 13, 2009 at 12:14:30 am
Hi Carlos,
Which Blackmagic Design product are you capturing with?
What version of drivers are you running now?
I'm pretty sure the HD-SDI output of the camera is in 59.94. Have you tried a 59.94 ProRes easy setup?
regards
Kristian Lam
Blackmagic Design
