Intensity Pro No HDMI Out
Jeff Kirkland
on Jul 31, 2009 at 10:00:28 am
Hi All,
Just bought an Intensity Pro and for the life of me I can't get HDMI out to work.
I have a Mac Pro, OS X 10.5.7, Final Cut 7.
I am testing by using the Black Magic playback software into an LCD television. I have no problem getting component out to work but HDMI simply displays "No Signal".
I have installed (and reinstalled) the latest drivers, and tried every resolution and control panel setting I can think of but I'm aiming for 720P PAL out.
I even read that it may work better in Slot 4 on the Mac but it didn't help.
Any thoughts or suggestions greatly appreciated?
Cheers,
Jeff K
Mikey Bouchereau
Re: Intensity Pro No HDMI Out
on Aug 2, 2009 at 2:22:39 pm
Have you changed the output settings in your system preferences? You need to change it from component out to HDMI.
Jeff Kirkland
on Aug 2, 2009 at 11:00:50 pm
Thanks for the reply,
If we're talking OS X control panel, then I only get two output choices and both of those include HDMI. It's currently set to HDMI + Y,YB,YR (or similar - not at the computer right now).
On the Final Cut timeline I've set the preview option to Black Magic 720P 50. No HDMI out.
I must be missing something somewhere...
Cheers
Jeff K
