Hooking up mixer to Decklink Studio
Bob Drwila
on Jul 30, 2009 at 10:59:50 am
Hi guys! We have the Decklink Studio card and want to hook up a mixer to it so we can ride the levels when the director is in the room. We would like to be able to monitor at least 6 channels of audio out. That way we can separate Dia and SFX and Music. Is there a way to do this? The Decklink Studio card has only 4 analog out or 6 AES/EBU out. We would like to use a MAckie 1402-VLZ mixer we already have. Is this possible somehow? Would another type of mixer work?
Thanks for your help!
Bob Zelin
Re: Hooking up mixer to Decklink Studio
on Aug 1, 2009 at 2:27:36 pm
because you own an anlaog mixer, the cheapest way to do this is with either AES/EBU to analog audio converters (Behringer makes a wonderful one for $99, but it will only do 2 channels at a time - but this will give you outputs 5 + 6 that you need) - or you can get the HDLinkPro from Blackmagic, which will de embed the SDI audio channels into six analog outputs, OR you can get the Blackmagic audio de embedder ($495) which will de embed 1-4 or 5-8 for you(you already have 1-4 analog outputs).
All of these solutions are cheaper than buying an AES/EBU mixer.
Bob Zelin
