Final Cut Pro 7 Support?
Steve Connor
on Jul 23, 2009 at 5:16:01 pm
Will there be a driver update shortly for the new FCP 7 version
Steve Connor
Adrenalin Television
Have you tried "Search Posts"? Enlightenment may be there.
Kristian Lam
Re: Final Cut Pro 7 Support?
on Jul 24, 2009 at 4:51:31 am
Hi Steve,
Sure. Current driver already work with it but we need to put in some presets for the new codecs that the new version supports.
regards
Kristian Lam
Blackmagic Design
Rhys Llewellyn
on Jul 26, 2009 at 10:18:21 pm
What new codecs are featured in fcp7?
Craig Thomas
on Jul 29, 2009 at 7:09:12 pm
Will you have HD VANC support? The Apple FCP 7 literature states that it support captioning. AJA's FCP 7 drivers state that they are supporting QuickTime Closed Captioning Track which is Apple's defined standard
for closed captioning support
Craig
Joshua Helling
on Jul 29, 2009 at 10:32:42 pm
We are working on adding the embedded time code support.
The new codecs that Kris mentioned are the new ProRes codecs.
Sincerely,
Joshua
Director of Support
Blackmagic Design Inc.
Jake Martin
on Jul 30, 2009 at 5:07:19 pm
Hi
I've been using FCP 7 and it seems to be working ok with Blackmagic's current driver but what I've found it only likes extended desktop as soon as I change that all my rushes turn white. It was pretty scary for a while until I figured out what was causing it. So I hope a driver that cuts out this and any other bugs will be available soon
Jake Martin
