SDI Output on DeckLink HD Extreme
Peter Heinrich
on Jun 27, 2009 at 12:44:56 pm
I am intend to use a DeckLink HD Extreme card, because it provides two SDI output channels.
From the description it is not absolutely clear if it is possible to play different clips on each SDI output channel at the same time.
Or is one channel the main playout channel and the other one is only for monitoring?
Thanks in advance for an answer.
Best regards
Peter
Peter H.
Bob Zelin
Re: SDI Output on DeckLink HD Extreme
on Jun 28, 2009 at 12:03:22 am
this is the correct answer.
bob Zelin
Kristian Lam
on Jun 30, 2009 at 6:13:42 am
The 2 outputs are the same and simultaneous.
regards
Kristian Lam
Blackmagic Design
