How much hard drive space to capture 1 hour HD with Multibidge?
Emad El Tawil
on Jun 15, 2009 at 11:38:33 am
Hello
I just want know average space required for capture HD video by multibridge from Decklink with uncompressed file or which codex will be better with good quality?
Best regards
Bob Zelin
Re: How much hard drive space to capture 1 hour HD with Multibidge?
on Jun 15, 2009 at 6:59:39 pm
Blackmagic should use this as a wonderful oppportunity to point to the URL that shows where their space calculator is.
In the mean time - this is the chart I use -
http://www.dulcesystems.com/html/video_space.html
Bob Zelin
Emad El Tawil
on Jun 15, 2009 at 6:53:17 pm
Thanks Bob for replay
but is multibridge use compersion when it capture video?
I have Raip inc system U320 3,5 TB that mean i can only capture 4 houre in system,
thanks
Best regards
Bob Zelin
on Jun 16, 2009 at 9:28:08 pm
Hi Emad,
the multibridge is an input output device. You choose in your Easy Setups your compression ratio - for example
ProRes422
ProRes422HQ
DVCProHD
uncompressed SD 8 bit
uncompressed SD 10 bit.
Depending on your compression ratio (or uncompressed video), you get different amounts of time you can capture. There is not one fixed answer. The higher the compression ratio, the more time you can capture on your drive array.
Bob Zelin
Emad El Tawil
on Jun 17, 2009 at 5:20:24 am
Hi Bob
thanks for you replay,
If i use DVCProHD compression how mush space for 1 hour?
Just i want to know how mush i need if i want to edit 20 hours HD?
Best Regards
Bob Zelin
on Jun 19, 2009 at 8:08:28 pm
DVCProHD 1 Terabyte - 20 hours
bob Zelin
