Intensity Pro audio problem
Matt Campbell
on Jun 3, 2009 at 9:01:59 pm
I'm having a heck of time trying to record aa audio scratch track through FCP, a Mackie 1202 and Intensity Pro card. I've done this a hundred times with no issues. Here's my set up and problem.
I'm getting crazy loud feed back through my mixer when I try and adjust my levels and gain.
Set up:
• Intensity Pro card, analog audio inputs and outputs loop through my Mackie 1202 tape input and outputs
• mic plugged into channel 3 via XLR
• video input device is powered on so that FCP sees the Intensity card, then video is unchecked in my capture window, clip settings so that only audio is recorded.
As mentioned above, I've done this hundreds of times with no issues. All the sudden, my audio comes in sweeky, almost robotic sounding, and with tons of feedback.
Any thoughts as to whats causing this?
OS 10.5.5, Mac Pro 2 x 3 ghz quad-core intel xenon, 9 gb ram, with BM Intensity Pro card
Jason Makiaris
Re: Intensity Pro audio problem
on Mar 31, 2015 at 4:59:08 pm
I just started having the same issue this morning. I know this post is pretty old, but were you ever able to find a solution?
© 2018 All Rights Reserved
