Multibridge Pro 2 - How can I sync Audio Outs?
Tangier Clarke
on May 22, 2009 at 2:58:10 pm
I want to screen a cut from someone on my 50" plasma using the HDMI outs (playback driven by Final Cut Pro). The speakers on the plasma aren't very good so I thought I'd set up my M-Audio speakers on either side of the TV and use the RCA outs from the Multibridge to send audio to those speakers as well - being that the Multibridge can do HDMI, SDI, and NTSC out simultaneously. However When I did this setup up the audio from the TV's speakers and from the M-Audios were out of sync. You could hear echo.
My hope was that the signal processing in the Multibridge Pro would make sure that all is in sync.
Is this something that can be adjusted. Am I doing something wrong?
Tangier
Margus Voll
Re: Multibridge Pro 2 - How can I sync Audio Outs?
on May 22, 2009 at 5:48:45 pm
Turn down TV audio as tv takes time to process video and audio.
Margus
http://iconstudios.eu
