16:9 SDI output with Decklink
Nihal Pehlivan
on May 18, 2009 at 10:04:38 am
Hi all,
I have 2 questions. Firstly, i have to get 16:9 SD out.
Is it possible to get 16:9 SDI output with Decklink cards?
Secondly, can i rotate video out 90 degrees with Decklink again?
Any help will be appreciated.
Thanks in advance
Nihal Pehlivan
http://www.teknomaks.com
Margus Voll
Re: 16:9 SDI output with Decklink
on May 19, 2009 at 8:22:25 am
Hi.
Absolutely you get 16_9 on sdi.
You just have to get model that will suit your needs.
You still have to see the tech properties for video material etc.
imo it is not possible to rotate in hardware sdi like that if you do not
have effects box capable of sdi.
Margus
http://iconstudios.eu
Nihal Pehlivan
on May 20, 2009 at 7:20:51 am
Thanks for your reply.
I have installed Decklink Pro with latest driver. But, i could not see any settings to adjust the output to 16:9. How can i do that? Or should i use another Decklink card to get 16:9 sdi?
Nihal
Margus Voll
on May 20, 2009 at 11:39:49 am
Hi.
What exactly is the device where you output ?
What os and what application you use.
As detailed question you have as detailed replay you get usually :)
Margus
