DeckLink HD Extreme, Color and RGB
Keith Pratt
on May 5, 2009 at 2:07:52 pm
Hello.
Simple query, I think. I have a DeckLink HD Extreme 2 and want to know if it's possible to get full RGB monitoring (over HD-SDI) from Color when grading DPX files.
Thanks in advance.
Kristian Lam
Re: DeckLink HD Extreme, Color and RGB
on May 6, 2009 at 8:54:53 am
Hi Keith,
The HD Extreme 2 has a 3 Gb/s SDI output which means the RGB 4:4:4 signal is sent via a single BNC connection instead of 2. If your monitor supports a 3 Gb/s SDI connection, you'll be able to monitor out of Color in RGB 4:4:4 with the card.
regards
Kristian Lam
Blackmagic Design
Keith Pratt
on May 6, 2009 at 10:01:51 am
All I needed to know. Thanks for the reply.
