Multiple HDLinks
Charles Caillouet
Multiple HDLinks
on May 2, 2009 at 12:58:44 am
Is there any way to control more than one HDLink with one Mac?
My Multibridge utility has a device menu but i don't see any provision for more than one device in the HDLink Utility.
I want to use two HDLinks as live SDI color correctors for remote cameras.
Do i need two computers to do this?
C. R. Caillouet
Vision Unlimited/LA
HD Production Technical Support since 1987
...searching for the right tool for the job...
Kristian Lam
Re: Multiple HDLinks
on May 6, 2009 at 1:59:44 pm
The current HDLink software only controls one device. However, the settings do stick even when disconnected from the USB connection if that helps.
regards
Kristian Lam
Blackmagic Design
Charles Caillouet
on May 6, 2009 at 4:02:58 pm
Kristian,
Thanks for the response.
That's about what i had figured out.
And the settings hold well. I swapped cables back and forth between two units on my last job. I will just have to add a USB switch to the mix.
crc
C. R. Caillouet
Vision Unlimited/LA
