Extreme HD hangs
George Kalishkin
Extreme HD hangs
on Apr 16, 2009 at 2:49:20 pm
i got a problem: Final Cut hangs, when playing video trough decklink extreme hd.
when clicking on timeline - video displays, when pressing space - hangs after one second.
if video output not selected - not hangs.
macpro 2.66, 4 gb ram, radeon 1900, 10.5.6, fc 6.0.5, qt 7.6, decklink drivers 7.1
i tried reinstall old drivers - the same problem.
Kristian Lam
Re: Extreme HD hangs
on Apr 16, 2009 at 11:59:48 pm
Is this a new install of the card? When did it last work?
Which setup are you using in Final Cut Pro?
Is the same thing happening when you play out with the Blackmagic Deck Control application?
regards
Kristian Lam
Blackmagic Design
George Kalishkin
on Apr 17, 2009 at 7:42:43 am
it works with tiger.
i use blackmagic pal.
when i use blackmagic dv - everything works. when i swith video output in dv setup to blackmagic - 8 or 10 - hangs on play.
Blackmagic Deck Control application - i will try.
