Apple "NONE" Codec
Tarquin Douglas
Apple "NONE" Codec
on Apr 7, 2009 at 8:46:29 pm
We have just moved onto a Blackmagic SDI card from an AJA card. I have always used NONE to capture in our (mostly) PAL footage. Does anyone else capture in using Apple NONE?
I am not sure but on one recent job there seemed to be higher levels of black in our Quicktime captured file (which ened up as an MPEG 2 on a DVD).
What is the best codec to capture in using the Blackmagic SDI card for the closet match to source material on a digibeta?
Any work flows you use would be great to know.
Cheers,
T
Scott Thomas
Re: Apple "NONE" Codec
on Apr 7, 2009 at 10:17:01 pm
I thought the NONE codec was an RGB codec?
Uncompressed 10bit would be the closest to the source material.
I would use the Animation codec for RGB material. It supports an alpha and uses a lossless compression to make the files a little smaller.
Tarquin Douglas
on Apr 8, 2009 at 1:39:57 pm
Many thanks,
T
