Premiere Pro 2.0 crashes with Intensity Pro
Serge Marcotte
on Apr 6, 2009 at 4:01:01 pm
The crash occurs on import. Time and time again. No error message. Premiere Pro simply vanishes from sight. I'm on XP Service Pack 2, Intensity Pro drivers 2.1.
All is well when monitoring with After Effects Pro 7.0. No problems whatsoever.
If anyone recommends updating drivers, please include a link. Thanks you.
Scott Thomas
Re: Premiere Pro 2.0 crashes with Intensity Pro
on Apr 6, 2009 at 4:56:25 pm
Does Premiere still crash if you uninstall the drivers for the Intensity?
If the Intensity is working OK with After Effects, I would be less likely to blame it for Premiere's problem.
Serge Marcotte
on Apr 6, 2009 at 6:14:56 pm
PP2 does, in fact, run fine if I uninstall Intensity. But I seem to have solved the issue but downgrading to previous drivers, specifically 2.0.
It seems OK so far.
