Anyone tried out BoinxTV or Wirecast with Intensity Pro?
June Kim
on Apr 3, 2009 at 4:29:41 pm
I picked up 2x Intensity Pro cards thinking that I can use On-air to record and broadcast. Little did I realize that On-air is strictly limited to recording. Now I'm left with either looking into an alternative software or going with a physical switcher.
I am going to try the demo versions of BoinxTV and Wirecast over the weekend. Has anyone done a similar setup? Any issues? Suggestions?
June Kim
Re: Anyone tried out BoinxTV or Wirecast with Intensity Pro?
on Apr 6, 2009 at 5:43:11 pm
I installed BoinxTV (demo) and was able to bring the 2x camera sources and switch/output using the software. However, I wasn't able to output @ 1080i (which is the input from the camera) and there seems to be a lag on the output from the software. Does anyone know how to tweak these settings? thanks
Jerit Abart
on Apr 6, 2009 at 9:10:05 pm
Which PCI slots are you using for your 2 Intensity Pro cards?
June Kim
on Apr 6, 2009 at 10:25:28 pm
Top two slots.. PCI 3 & 4
I had issues earlier when I placed the cards on slot 2 and 3.
