SDI A & B on MultiBridge Extreme
Steve Cohen
on Mar 30, 2009 at 6:53:08 pm
We have several Black Magic Multibridge Extreme units here and had noticed there is an SDI Input A & B as well as an Output A & B.
What are these for?
Can you have 2 different SDI inputs connected and switch between them in the preferences?(I've never seen a setting for this)
Thanks in advance.
Steve Cohen
Senior Editor
O2 Media Inc.
Kristian Lam
Re: SDI A & B on MultiBridge Extreme
on Mar 30, 2009 at 9:31:42 pm
Hi Steve,
Input B the second link of a dual link HD-SDI connection for use with the HDCAM-SR while capturing 4:4:4 RGB 10-bit HD. It cannot be used as a separate SDI input.
regards
Kristian Lam
Blackmagic Design
Thomas Rued
on May 4, 2009 at 8:44:07 am
Hi Kristian,
I'm having a similar problem - is there any way you can capture Full HD from two individual sources at the same time using the MultiBridge?
(I'm using the MultiBridge Pro)
Best
Thomas Rued
