Decklink Extreme to SRW-5800 drift problems
Kevin Johnson
on Mar 24, 2009 at 5:15:40 pm
I have a 720p 8 bit sequence I am trying to output to the SR deck at 720p. The insert hits the edit point, however by the time bars and tone are done, my slate has drifted 4 frames. I'm using the Decklink 720p 8bit easy setup. Is there a way to adjust for this?
Any help would be greatly appreciated. Deadline is approaching!
Kevin
FCP Editor
Washington, DC
Kevin Johnson
Re: Decklink Extreme to SRW-5800 drift problems
on Mar 24, 2009 at 6:07:27 pm
I also had the exact same problem on our D5 deck. Do I need to adjust the frame offset control in a/v settings?
FCP Editor
Washington, DC
