New Decklink Studio - SDI embedded audio issue.
Sam Lanes
on Feb 27, 2009 at 10:26:51 am
I would like to raise an issue I have been having with the new BM Decklink Studio cards.
My setup is a new Mac Pro OSX 10.5.6, FCP 6.0.5 and Quicktime 7.6. The Blackmagic Decklink drivers I am using are 6.8.8 (although I have also tried the 6.8.7 drivers as well).
My issue is that when I attempt to capture uncompressed SD footage via the SDI connection, the embedded audio is peaking on channels 3/4, which is bleeding into the main mix (even when the channels are deselected, and I am only outputting audio via channels 1/2). It appears to be producing a repetitive 'clicking' noise on these channels.
There appears to be no way of reducing this peaking, and it is clearly visable on all the audio metres within FCP.
The HD-SDI embedded audio is perfectly fine, which makes it all the more odd. Analogue audio is also ok. Also, downconverting from HD to SD using the Decklink Prefs is fine.
I have tried two Decklink Studio cards and tried them in an older Mac Pro with a similar spec but with the same outcome.
I have also tried a different SD-SDI source.
I am wondering if anyone else has experience similar with this input, or if Blackmagic can tell me if this is a known bug.
Sam
Margus Voll
Re: New Decklink Studio - SDI embedded audio issue.
on Feb 28, 2009 at 9:10:22 am
Hi. It seems to me if it is not from settings etc the it might be the actual unit you use. Can you ask another unit form your reseller for testing ?
Margus
http://iconstudios.eu
Sam Lanes
on Feb 28, 2009 at 2:01:28 pm
HI Margus,
Thanks for the response. I have tried this on two units with the same result.
