Decklink Extreme PCI + Vista 64 + 4G ram
Yasser Amin
on Feb 12, 2009 at 1:26:45 pm
Hi
Is there a solution to let Decklink Extreme PCI to work under Vista 64 with 4G ram ?
No output or working premiere Time line until reduce the memory to 2G ram
thanks
Thomas Madroszkiewicz
Re: Decklink Extreme PCI + Vista 64 + 4G ram
on Apr 16, 2009 at 1:46:02 pm
Hey Yasser!
I'm having the same problem now.
I tried almost everything. Even contacted Blackmagic but there were no answer.
Vista x64 Ultimate + Tyan Thunder K8WE mobo + Declink Extreme PCI + 4gB kingston ECC RAM. And the card works only if I remove 2GB of ram.
Do you get some help with this.. or you changed to Vista 32??
Cheers,
Thomas
Yasser Amin
on Apr 16, 2009 at 9:42:40 pm
Hello Thomas
No way to get Decklink PCI working under XP or Vista 64 with 4G ram
I switched to Vista 32 with CS4 and last driver 7.1 and every thing working stable
regards
Yasser
Kristian Lam
on Apr 16, 2009 at 11:58:10 pm
The PCI version of DeckLink Extreme will not work with more than 2 Gb of RAM, only the PCIe version.
regards
Kristian Lam
Blackmagic Design
on Apr 17, 2009 at 7:53:47 am
Thanks for the answers. Really bad news although.
Is there any chance for some kind of firmware update to this card or I should change for something else.
Yasser Amin
on Apr 18, 2009 at 12:36:55 pm
any firmware update for Decklink cards is integrated in the driver
on Apr 20, 2009 at 8:59:24 am
Great.
Just wondering why Blackmagic not mentioning this issue on their site.
They even write in Decklink minimum system requirements Windows Vista recommended 4GB ram.
I did not find any clue on this in the support section.
or maybe a red-white banner..
"FOLKS DON'T BUY THIS CARD IF YOU USE MORE THAN 2GB RAM"
Now I have two options throw away 2x1gb Kingston ECC RAMS.. or sell somehow Decklink Extreme PCI and buy PCIe version. :(
Anyway...thanks for the help everyone. :)
