iLife 09 GarageBand will not work with Decklink Driver?
Sean Lander
on Feb 4, 2009 at 12:22:42 pm
Just got a copy of iLife 09 but have found that GarageBand will not work properly at all if you have the Decklink selected as the sound output device. Is there a solution to this? Do I just reinstall the drivers perhaps?
Sean Lander
Re: iLife 09 GarageBand will not work with Decklink Driver?
on Feb 4, 2009 at 12:39:26 pm
To answer my own question it would seem that re-installing the drivers does work but you may need to manually select the decklink driver in GarageBand preference for output.
R E D N A I L - M E D I A
web: http://www.rednail.com.au
email: rednail@me.com
Ara Keshishian
on Nov 24, 2009 at 7:17:04 am
Hi I can get my Decklink Extreme 3 to work with Garageband, did you figure it out? I tried switching output in GB to Decklink with no change....many thanks
