Can i read out the VANC data from an SDI Stream?
Steffen Börner
on Jan 28, 2009 at 1:01:42 pm
Hello,
i want to get the Timecode coming in the VANC data of an SDI Videostream. The Video comes from an RED Camera which put the Timecode in the SDI Data. I have a HD Extreme and want to know whether it's possible to read out the Timecode.
Kind regards
Margus Voll
Re: Can i read out the VANC data from an SDI Stream?
on Jan 31, 2009 at 10:01:24 am
Hi.
It seemes that RED is the key part here as BM should read vanc trough SDI. I have done it with digibeta and SDI.
But why use SDI with RED enyway ?
Margus
http://iconstudios.eu
Mike Reddy
on Nov 15, 2011 at 3:08:31 am
Yes absolutely. Reading the VANC data from an SD-SDI or HD-SDI stream (that includes Closed Captioning data) is often of great help - it is necessary in order to verify CC, to monitor things like AFD or Broadcast Flag, to capture VANC info such as CC data to a separate file, etc.
Vela Research has solutions, one of which is called ArgoNavis, geared to monitoring, verifying and/or capturing VANC data from SDI streams.
