Multibridge Pro HDMI video monitoring not working
Russell Reinsel
on Jan 20, 2009 at 5:48:47 pm
My mulitbridge Pro quit outputting HDMI video. (final cut pro - 2X3 GH Quad-Core Intel mac) Audio still works but no video. It has worked perfectly for the past year. I trashed my prefs in FCP and used the same easy setup that normally works.
Any help or suggestions on how to fix the problem would be greatly appreciated.
thanks
Andres Posada
Re: Multibridge Pro HDMI video monitoring not working
on Feb 17, 2009 at 6:07:29 pm
Have you received any info on how to have HDMI monitor out from the Multibridge Pro? Please help me. Thank you.
Kaku Ito
on Feb 19, 2009 at 4:59:04 pm
The HDMI from Multibridge Pro should be working, at least at my clients.
Which video format are you working with?
Andres Posada
on Feb 24, 2009 at 5:04:17 pm
I had a similar problem. The answer was to use a shorter length HDMI cable. I went from a 12 feet to a 6 feet cable and it works flawlessly.
