Decklink HD Extreme monitor HDMI and analog??
Christopher Grosso
on Jan 16, 2009 at 1:44:24 am
I monitor to an HDMI monitor but can I monitor to a analog at the same time? Doesn't seem to work I would think that the signal would be down-converted.
Using FCS 2
Produce | Shoot | Edit
Take Two Visual Media
http://www.take2vm.com
Kristian Lam
Re: Decklink HD Extreme monitor HDMI and analog??
on Jan 16, 2009 at 3:05:58 am
Depends on what kind of analog. All outputs are live but if you're monitoring HDMI, then the analog output that you can monitor is component as that will also be in HD.
regards
Kristian Lam
Blackmagic Design
Christopher Grosso
on Jan 16, 2009 at 3:14:35 am
Thanks for the fast reply Kristian. I have the component going to a BetaSP deck, then the composite output from the Beta to the monitor. The deck shows and error code on it's display.
