Deckline HD Extreme SDI monitor
Harry Dawson
on Jan 8, 2009 at 4:44:32 am
Hi. I have a Panasonic BT-LH80WP with an SDI option. I was hoping to
monitor 720p from the FCP timeline. It displays a still frame but
does not move. What's up?
Bob Zelin
Re: Deckline HD Extreme SDI monitor
on Jan 8, 2009 at 4:58:59 am
your capture compression does not match your sequence compression.
May I suggest that you open your clip, and then open a new sequence, and I bet it plays.
bob zelin
Harry Dawson
on Jan 8, 2009 at 7:21:28 pm
OK. Compression matches (I've been editing on this for a year without
rendering timeline) but I was trying to play through the SDI HD connector in the BT-LH80WP, so I went to RGB it plays fine 720p 59.94. Then of course I had to have the right settings chosen in the video output in FCP. (Got a new machine for Christmas, with a new Decklink card and it takes a bit to get everything up and running.)
Harry Dawson
on Jan 8, 2009 at 7:40:13 pm
OK an update. The SDI HD connection is now working. I upgraded the new software and firmware from Declink that just came out. Maybe that did it.
Eric pascal
on Jan 22, 2009 at 3:05:44 pm
I've bought a Decklink HD Extreme and I don't know how to capture with, however it is correctly installed. I have Adobe Premiere Pro CS3 'n Pro 2.0. Could someone help me ? Should I buy a tape deck RS-422 or can I directly capture via camera.
