Wanting to get it right!
Grant Goss
on Dec 25, 2008 at 7:05:44 am
I'm new here, and maybe I'm in the wrong place to be asking this question, but here I go.
I'm building the following system, as a starting point.
Blackmagic design DeckLink HD Extreme card.
3ware Raid controller card. 9650se 4lpml.
4 WD 1TB 7200rpm Caviar Black HD. Raid 5.
WD 3oogig 10k VelociRaptor HD for the OS.
ASUS P5E Deluxe Motherboard.
Intel Core 2 Q9550 Yorkfield Quad Core 2.83 Ghz
8 Gigs of Corsair XMS3 DHX Ram.
Cool Master Hyper 212 Copper/Aluminum heat pipe CPU Cooler.
PC Power 750w Quad power supply.
LG 22x SATA Dual Layer DVD+/-RW
AS for the OS, Windows XP Pro.
Adobe CS3.
I'm just using this system at home with low to mid end Video.
One more Question.
Will the Sony XDCAM EX PMW-EX1 work well with this system?
Thanks for your time and input.
Aristides Tiropolis
Re: Wanting to get it right!
on Dec 25, 2008 at 6:05:11 pm
[Grant Goss] "AS for the OS, Windows XP Pro."
Why would you buy 8 gigs of memory and install WinXP? Five of them will be left unused.
As for the rest of the system, it'll handle the ΕΧ-1 footage fine, but you could always go with the i7 architecture, more performance less power consumption, more PCIe slots on X58 mainboards, why not?
You could also add a blu-ray writer for backup...
Aristides Tiropolis
on Dec 25, 2008 at 6:10:32 pm
Also, the P5E is a DDR2 motherboard and you're stating a purchase of DDR3 memory
Grant Goss
on Dec 25, 2008 at 9:41:03 pm
by Aristides Tiropolis (Aristides) on Dec 25, 2008 at 12:10:32 pm
True the P5E is DDR2
P5E Deluxe is DDR3.
Grant Goss
on Dec 25, 2008 at 9:35:03 pm
Could I run Vista Ultimate 32bit version without running into driver problems with the Blackmagic card and Adobe CS3? Then I could use all the ram.
Aristides Tiropolis
on Dec 26, 2008 at 4:42:59 pm
The P5E Deluxe is DDR2 as well.
Vista 32 will support a maximum 4Gb of memory. Only x64 systems support more than 4 gigabytes of memory on windows.
Vista ultimate x64 supports blackmagic and The Adobe CS3 suite.
Sam Carleton
on Jan 3, 2009 at 4:12:30 am
As Aristides said, you need a 64-bit OS. If you have a close look at the web site, you will see that they DO have drivers for both Vista 64-bit and XP 64-bit, take your pick.
By day I am a software developer. My laptop is 64-bit Vista and I never have any driver issues. Well this is not 100% true, a 4-year-old blue tooth usb dongle did not have drivers for the laptop, but it was 4 years old.
Personally, if I where you, and I am sort of because, I too, am building my first editing system, I would not install XP on a new machine, the OS is 6 years old! Vista w/ SP1 is a wonderful OS, far better then XP in many regards and simply far more modern.
Go with 64-bit Vista and you will be a happy person!
Sam
