Decklink & XDCAM
Aaron Cadieux
Decklink & XDCAM
on Dec 19, 2008 at 3:13:07 am
We all know Decklink supports native editing of HDV when using the 8-bit preset in PPCS3. When the heck are they going to do the same for support of XDCAM?????????
Callum McLay
Re: Decklink & XDCAM
on Dec 19, 2008 at 2:32:48 pm
Hi Aaron
You can already use XDCam with a Decklink card, we just don't have a preset for this at the moment. Because Premiere Pro CS3.2 can natively read MXF files and the XdCam format, you can import your XDCam footage onto a Blackmagic timeline, and you should be able to get real time playback.
Callum McLay
Technical Support Consultant
Blackmagic Design EMEA
Aaron Cadieux
on Dec 19, 2008 at 3:03:19 pm
Thanks for your reply.
Yeah, I've tried bringing the XDCAM files into a Blackmagic preset project.
I imported XDCAM 60i footage into a Blackmagic 8-bit 29.97 interlaced project. When I'd bring the XDCAM files onto the timeline, they appeared to need rendering. Also, when I play the XDCAM files on the timeline, they keep dropping frames.
-Aaron
