intensity pro with parallels
Gerard Weemhoff
on Dec 17, 2008 at 10:38:59 pm
for HD broadcasting to mogulus I needed to install window's XP on my Mac Pro because On2 or Flash media encoder [ is unfortunatly only available for windows. I used parralels to realize this. I installed the Intensity Pro correctly OSX and XP but The problem I have now is that I can't configure the Intensity Pro in the configuration: I can't set the capture or output device, these options are disabled.
anyone a suggestion or solution?
Thanks Gerard
Joshua Helling
Re: intensity pro with parallels
on Dec 17, 2008 at 11:06:15 pm
I am not 100% sure about this, but I don't think Parallels will let you access hardware in XP mode. I believe this is because it is simply XP running over OSX.
I am pretty sure you need to use bootcamp to do that.
Director of Support
Blackmagic Design Inc.
© 2018 All Rights Reserved
