Does a version of the decklink card allow for simultaneous input/output?
Mark Wyse
on Dec 17, 2008 at 9:44:27 pm
Hello,
Is there a version of the decklink card that allows simultaneous input/output? I need to be able to capture an SDI video source and immediately be able to cue/pause/playback the file in SDI while it is still recording. I am still searching for software that will allow this but I am wondering if one of the decklink cards allows this kind of input/output? If not, can I install 2 decklink cards in the same system to accomplish independent input and output?
Thank you for your help,
Mark Wyse
Madison, WI
Joshua Helling
Re: Does a version of the decklink card allow for simultaneous input/output?
on Dec 17, 2008 at 11:07:38 pm
Unfortunately no. Our boards do not do this. However this can be achieved by using two boards in the same machine on a PC. Of course a specialized software is required to handle both cards. But in theory you could use a setup like this to capture with one board and output with another.
Sincerely,
Joshua
Director of Support
Blackmagic Design Inc.
