Digital Fusion Compatibility
Mike Zimbard
on Oct 28, 2008 at 3:07:26 am
We are looking to set up a standalone Fusion workstation and output to an HD monitor so that we can see the proper output of our flow before we feed the renders to the edit room. I know HD extreme supports combustion for real-time monitoring output on Windows. I was wondering if it also supports Fusion. Any help is greatly appreciated. Thanks!
- Mike
Kristian Lam
Re: Digital Fusion Compatibility
on Oct 28, 2008 at 3:30:35 am
Hi Mike,
Yes we support Fusion. In fact, you can find our products listed here:
http://www.eyeonline.com/Web/EyeonWeb/Products/supported_hardware/supported...
regards
Kristian Lam
Blackmagic Design
Mathieu Marano
on May 25, 2009 at 7:53:19 pm
Actually Decklink drivers don't work with Fusio 5. If you open the panel in Fusion prefs it crashes. It's a known issue and BMD knows it. They are working on it. Here is part of the email i received:
Currently there is a bug with Fusion support and it is currently not
working. There was a big change in the code to accommodate a bunch of
different things and one of the unforeseen side effects was that it broke
the Fusion support.
Received May 14th 2009
Mathieu Marano
online editor - motion graphics - Post-prod director
Directeur technique de post-production
Le Bureau de post production
Administrator of the Montreal Final Cut User Group
http://www.finalcutmtl.org
Matt Stalker
on Aug 4, 2009 at 5:26:12 pm
Was this problem ever addressed? I still get a program crash when accessing the blackmagic prefs in fusion...
Matt
Matt Stalker
Center City Film & Video
mstalker@ccfv.com
