workgroup hub and downconvert
Baz Leffler
on Oct 18, 2008 at 5:39:40 am
Does anyone here know how to set the output of the workgroup hubs downconverter to NOT put letterboxing on the output?
Baz
What would I do without the 'UNDO' button!!!!
Chris Pearse
Re: workgroup hub and downconvert
on Oct 20, 2008 at 3:09:47 pm
Hi Baz,
Unfortunately there is only one type of downscaling available on the Workgroup Videohub. The downconversion feature on the Videohub is more for monitoring purposes than anything else.
Should you be using one of the Decklink cards that allows downconversion on output, such as the Decklink HD Extreme 2, you can set it to downconvert in either letterbox or anamorphic for SD. This can then be sent into the Videohub.
Chris Pearse
Technical Support Consultant
Blackmagic Design EMEA
