cineSpace and LUT's
Margus Voll
cineSpace and LUT's
on Oct 14, 2008 at 5:18:42 pm
Hi.
I wonder if HDLink Pro and Multibridge pro 2 will use the same LUT's
generated by Cinecube or are they different and i should get HDLink Pro
for that reason?
Margus
http://iconstudios.eu
Gabriele Turchi
Re: cineSpace and LUT's
on Jan 1, 2009 at 8:52:06 pm
Hi Margus,
did you ever figure out this?
G
Margus Voll
on Jan 2, 2009 at 9:07:08 am
Hi.
Yes i figured it out ... I contacted people behind cineSpace and got VERY detailed information haw and what to use etc. HDLink pro is way to go i think.
I advise you contact them ... they are very helpful.
Margus
Gabriele Turchi
on Jan 2, 2009 at 6:12:16 pm
Thanks Margus...
i sent them an email days ago but no answer..(maybe in Holiday...)
i have some doubt about how use the 3D Lut (and creted those 3D Lut) for device connected by SDI (With HDLink in the middle...)
I mean,i understand how profile and than create a lut for a monitor connected by DVI...but how you create a profile (using cineprofiler) using a monitor that in the workflow will be connected to and SDI card ...?
I mean how cineprofiler can send the test pattern (to crete the profile) trough the SDI card...
Also:Let say i want to connect an SDI Camera out and use HDLINK pro whit the LUT generated by Cinecube...same thing ...how that LUT could be precise if when was created the monitor was connected to another source (graphic card?)
Does it make sense what i am saying?
G
