HDLink - autoswitch input
Christopher Tay
on Oct 11, 2008 at 3:00:49 am
Does anyone know if the HDLink will automatically switch itself to the input signal ?
For example if I have it setup with dual BNC for HD 4:4:4 monitoring, will it be able to automatically switch between a single link SD/HD and dual link HD input ?
I'm using the HDLink to feed to a HDMI projector and I will be switching between PAL 4:2:2 and HD 4:4:4 so just wanna know if the HDLink will autoswtich as it's going to be placed up there close to the ceiling with the projector.
Thanks.
-chrispy
Callum McLay
Re: HDLink - autoswitch input
on Oct 17, 2008 at 10:05:05 am
Hi Christopher
Both the standard HD Link and the HD Link Pro will auto switch their input depending on whether you input Single link, Dual link, or in the case of the HD Link Pro 3 Gb/s SDI.
Hope this helps!
Callum McLay
Technical Support Consultant
Blackmagic Design EMEA
