capturing audio with blackmagic using a XLR mic
Luiz Felipe Dianese
on Oct 10, 2008 at 1:05:14 am
I just got a Decklink Hd Extreme, and i was hoping i could capture audio by directly connecting my XLR self powered mic into the card cable. Am i having alucinations or is there anyway i can do that. Any help will be aprecciated, thank you
jason levy
Re: capturing audio with blackmagic using a XLR mic
on Oct 11, 2008 at 1:31:54 am
It's a line level input so you will need some kind of preamplifier, like a small mixer.
jason
Margus Voll
on Oct 11, 2008 at 6:42:05 am
I do not know if your computer sees your capture card directly.
Probably not.
What i have done is start Log and capture in Premiere or finalcut.
Disable video input in your settings (you still need reference video in and / or black video in). Press capture now and record your audio.
And yes you need pre amp probably to your mic.
Generally it is possible but not so straight forward.
Margus
http://iconstudios.eu
Luiz Felipe Dianese
on Oct 11, 2008 at 7:14:24 pm
Thank you for the help, i got a mixer and ill try to make this connection and capture tha audio.if anything go wrong i come back here.
Thank you
Director/Editor in Brazil
jason levy
on Oct 11, 2008 at 11:01:52 pm
I have heard that you will need some kind of video input as well as the audio even if you are not capturing video.
jason
Aristides Tiropolis
on Oct 12, 2008 at 2:19:15 am
I Have tried this, it works, but only when capturing in Premiere, it's not something you can really control or has any real usability, and the inputs are really there for balanced inputs from i.e beta decks.
You have to use a separate solution for this, like for instance a firewire external audio card.
Aristides Tiropolis
on Oct 12, 2008 at 2:20:19 am
Oh! And you do need a phantom powered preamp for the mike first.
Margus Voll
on Oct 12, 2008 at 7:16:26 am
Hi.
All is true as i sayed between the lines you need phantom power which mixer should give and you need sync (sync is more optional i think) and black (eny video) in and you can do it with premiere or finalcut only. But still it is doable if you do not want to have separate audio card.
Margus
