Is there Video format keep the Alpha channel in it?
COW Forums : Corporate Video
almozayaf own
on Jan 21, 2009 at 5:09:56 pm
Stephen Smith
Re: Is there Video format keep the Alpha channel in it?
on Jan 21, 2009 at 10:18:47 pm
Animation set to Millions +
Stephen Smith
Salt Lake Video
Check out my DVD Money Making Graphics & Effects for Final Cut Studio 2
almozayaf own
on Jan 22, 2009 at 12:39:53 pm
What?
Stephen Smith
on Jan 22, 2009 at 3:50:11 pm
"Animation" is a video codec. In its settings, you need to set it to "Millions of Color +". The plus stands for the Alpha Channel (Transparent part of the video).
Stephen Smith
Salt Lake Video
almozayaf own
on Jan 22, 2009 at 5:10:11 pm
so is it work fine with AE?
Stephen Smith
on Jan 22, 2009 at 5:16:09 pm
It works great in AE and any other professional video application.
Stephen Smith
Salt Lake Video
almozayaf own
on Jan 23, 2009 at 7:50:36 am
i didn't find that format how can i make it.
Stephen Smith
on Jan 23, 2009 at 4:25:41 pm
What program are you using?
Stephen Smith
Salt Lake Video
cowcowcowcowcow
Dan Asselin
on Jan 24, 2009 at 4:00:31 am
Actually Steven means quicktime video. And regardless of what program you use to create your Quicktime file when it comes to generating it any program will give you the opportunity to choose which Codec you will use. At that point choose the Millions + setting that he mentioned and you will have synchronized sound and motion video with a great alpha channel. As a side note the guys at Digital Juice use a program called "The Juicer" to generate their clips and that is where I first learned this. If you are just starting out you could do a lot worse than looking into their products. (The Juicer is free but only runs their clips)
almozayaf own
on Jan 24, 2009 at 8:00:41 pm
thanks that help
John Grote, Jr.
on Feb 4, 2009 at 2:09:12 am
I know you have had your question answered, but next time could you be a little more specific in what program you are using and what you would need the alpha channel for.
Cheers,
John
J. Grote, Jr.
