Panasonic AG-HMC40 or HC-VX870 (HD prosumer vs 4K consumer)
COW Forums : Event Videographers
Kyle Walker
on May 18, 2015 at 7:14:33 pm
I'm trying to upgrade the old mini-dv gear I use for long-form shoots (i.e. concerts, lectures, etc). I'm also trying to keep it under $1000
Would one recommend a brand new HC VX870, which is apparently one of the least expensive 4K cameras on the market right now. Or would one recommend a gently used HMC40 for $850 on Craigslist.
I'm not sure if it's smarter to go with a more consumer grade camera but have one that may be sustainable quality for longer, or one suitable for more prosumer grade setups but been out for a few years.
Most of what I do for these types of shoots is throw the camera on a tripod and press record. I have external audio gear I set up as well.
I must admit that larger form cameras (prosumer, professional) are what I would ideally like to be seen with for professional reasons in regards to how people take one more seriously with larger gear. Though I know that sounds somewhat unreasonable. But I can't dismiss that that is a factor.
Any advice appreciated!
Bill Bruner
Re: Panasonic AG-HMC40 or HC-VX870 (HD prosumer vs 4K consumer)
on May 20, 2015 at 2:28:44 pm
Hi Kyle - sadly, the HMC40 will produce relatively low resolution images by modern standards.
I would choose the VX870 (or the $998 4K Sony AX33, which has a viewfinder) over the HMC40.
Here is what the AX33 can do:
(please watch at 2160p and your monitor's highest resolution)
If you want a consumer camcorder to look more "professional", all you need is a square lens hood or a $50 matte box.
Here is a picture of my Panasonic TM900 consumer camcorder with a pro mic and a matte box.
Here it is with the matte box, an LCD hood and a consumer mic.
Hope this is helpful and good luck with your upgrade!
Hybrid Camera Revolution
© 2018 All Rights Reserved
