iriver tie mic.
COW Forums : Event Videographers
robertbec
iriver tie mic.
on Nov 4, 2005 at 4:34:46 am
hi there
can someone please tell me what is the best tie mic. to use with the iriver.
Robert
velma
Re: iriver tie mic.
on Nov 4, 2005 at 12:03:52 pm
By tie mic, I'm assuming you mean lav mic? I use two different lav mics. One is the Azden EX-503 lav mic. It works great. I also use a mic from Giant Squid.
Because it's a little more sensitive, I use the Giant Squid mic to pick up the ambiant music like the organ, speakers. I use the Azdens to mic people. Both are very reasonably priced and work great.
good luck,
velma
Doug Graham
Re: iriver tie mic.
on Nov 4, 2005 at 2:27:56 pm
The Giant Squid has another desirable feature: they make a model especially for the iRiver which allows you to record in mono, doubling your recording time.
This is needed, because the iRiver reverses the normal standard (mono from right channel) and uses mono mic from left channel...without the correct wiring of your mic plug, going to mono mode will result in no recorded audio.
Regards,
Doug Graham
robertbec
Re: iriver tie mic.
on Nov 4, 2005 at 3:01:42 pm
Thanks for your quick response and great info.
Robert.
