"Less than" character makes rest of post invisible
COW Forums : Letters to the COW Team
Kalle Kannisto
on Apr 17, 2016 at 7:50:42 am
Hi. I made a post where the "less than" character in a piece of code in quotes, which resulted in the paragraph text after that character disappearing on the forum. The full text shows up when editing, but when posted, it doesn't.
Actually, it seems a bit more complicated, for just this "<" doesn't do it, but the code I wrote did.
I changed the text to code text to make it show, but I thought I'd alert you to this issue. Clearly code is meant to be set as code...
Actually, I'll put the same piece of code here:
Does my text show if it contains the string "Math.abs(A-B)
Ok, so it disappears.
Abraham Chaffin
Re: "Less than" character makes rest of post invisible
on Apr 17, 2016 at 3:03:30 pm
Hello Kalle,
Yes, the less than character is a special character in Web pages and is used to write code. If you look at the note above the post boxes it says: "Note: The following are HTML characters and may cause parts of your post to disappear if not used correctly: < > &". You might want to read this post for more info:
https://library.creativecow.net/articles/lindeboom_kathlyn/whipped_cream.ph...
Abraham
Kalle Kannisto
on Apr 29, 2016 at 8:37:34 pm
Well well, looks like I never really fully registered the exact content of that note...
