Lucy you've got some splainin to do
COW Forums : Letters to the COW Team
Jim Leonard
on May 13, 2015 at 1:10:38 pm
I couldn't resist using that great line, Ricky Ricardo used when there was a problem on the "I Love Lucy" show, as my subject line.
I found this problem with CreativeCow's "My profile" page: I put in my links to YouTube as requested:
Because these are Youtube's "Share" links. I don't know what they are smok'in over at YouTube, but youtu.be really?
Your software changes them to:
http:/fLzKL2ruGBs,
http://Yd2Jzi3GGwE,
http://T20l82o2t30
Which will not work in this century.
Soooo, CreativeCow.net has been around for many years and has thousands of members. I'm the First guy to notice this?
Just Saying...
Lenny - Production
Abraham Chaffin
Re: Lucy you've got some splainin to do
on May 13, 2015 at 6:42:55 pm
Hello Jim,
Take a look now. I believe it should be fixed. Thanks for pointing this out!
Abraham
Jim Leonard
on May 14, 2015 at 5:58:08 pm
Hi Abraham,
Nope. It still looked the same when I went to edit it. You need to change the format from "http://www.youtube.com/watch?v=" to the "http://www.youtu.be" code. You can't embed the "watch?v=" anymore. Some videos will not load because they are restricted to run "locally," on YouTube.com domain only.
Note: When I posted this to you, I listed the links using the old "watch?v=" format and the did not work on your site. Only the http://www.youtu.be links showed the video.
"To Err is human. But to really screw things up, you need a computer."
Lenny - Production
Abraham Chaffin
on May 14, 2015 at 8:23:48 pm
The YouTube reference URL there is simply a reference for people to know what to put into the field. YouTube still uses that URL format. The idea is to put the YouTube video code in there, not the embed code.
Abraham
