Converting YUV data to AVFrame
COW Forums : Letters to the COW Team
Gaurav Pathak
on Apr 28, 2015 at 6:04:27 am
Hello all,
I am working on encoding a raw yuv stream coming directly from webcam, using v4l2. The issue that I am facing is that even after using avpicture_fill and assigning every buffer separately
frame->data[0] = buffers[buf.index].start;
frame->data[1] = (buffers[buf.index].start)+1;
frame->data[2] = (buffers[buf.index].start)+3;
The output is not getting encoded and I am getting raw video.
My Code is:
#include "math.h"
#include "libavutil/opt.h"
#include "libavcodec/avcodec.h"
#include "libavutil/channel_layout.h"
#include "libavutil/common.h"
#include "libavutil/imgutils.h"
#include "libavutil/mathematics.h"
#include "libavutil/samplefmt.h"
#include "stdio.h"
#include "stdlib.h"
#include "string.h"
#include "assert.h"
#include "getopt.h"
#include "fcntl.h"
#include "unistd.h"
#include "errno.h"
#include "malloc.h"
#include "sys/stat.h"
#include "sys/types.h"
#include "sys/time.h"
#include "sys/mman.h"
#include "sys/ioctl.h"
#include "asm/types.h"
#include "linux/videodev2.h"
#define INBUF_SIZE 4096
#define AUDIO_INBUF_SIZE 20480
#define AUDIO_REFILL_THRESH 4096
#define CLEAR(x) memset (&(x), 0, sizeof (x))
unsigned char *outbuffer = NULL;
unsigned long buff_siz = 0;
char out_name[256];
typedef enum
#ifdef IO_READ
IO_METHOD_READ,
#endif
#ifdef IO_MMAP
IO_METHOD_MMAP,
#endif
#ifdef IO_USERPTR
IO_METHOD_USERPTR,
#endif
}io_method;
struct buffer
void *start;
size_t length;
static io_method io = IO_METHOD_MMAP;
static int fd = -1;
struct buffer * buffers = NULL;
static unsigned int n_buffers = 0;
// global settings
static unsigned int width = 640;
static unsigned int height = 480;
static unsigned char jpegQuality = 70;
//static char* jpegFilename = NULL;
static char* deviceName = "/dev/video0";
AVCodec *codec;
AVCodecContext *c= NULL;
int i, ret, x, y, got_output;
FILE *fout;
AVFrame *frame;
AVPacket pkt;
uint8_t endcode[] = { 0, 0, 1, 0xb7 };
static int num=0;
Convert from YUV422 format to RGB888. Formulae are described on http://en.wikipedia.org/wiki/YUV
\param width width of image
\param height height of image
\param src source
\param dst destination
static void YUV422toRGB888(int width, int height, unsigned char *src, unsigned char *dst)
int line, column;
unsigned char *py, *pu, *pv;
unsigned char *tmp = dst;
/* In this format each four bytes is two pixels. Each four bytes is two Y's, a Cb and a Cr.
Each Y goes to one of the pixels, and the Cb and Cr belong to both pixels. */
py = src;
pu = src + 1;
pv = src + 3;
#define CLIP(x) ( (x)>=0xFF ? 0xFF : ( (x) <= 0x00 ? 0x00 : (x) ) )
for (line = 0; line < height; ++line) {
for (column = 0; column < width; ++column) {
*tmp++ = CLIP((double)*py + 1.402*((double)*pv-128.0));
*tmp++ = CLIP((double)*py - 0.344*((double)*pu-128.0) - 0.714*((double)*pv-128.0));
*tmp++ = CLIP((double)*py + 1.772*((double)*pu-128.0));
// increase py every time
py += 2;
// increase pu,pv every second time
if ((column & 1)==1) {
pu += 4;
pv += 4;
Print error message and terminate programm with EXIT_FAILURE return code.
\param s error message to print
static void errno_exit(const char* s)
fprintf(stderr, "%s error %d, %s\n", s, errno, strerror (errno));
exit(EXIT_FAILURE);
Do ioctl and retry if error was EINTR ("A signal was caught during the ioctl() operation."). Parameters are the same as on ioctl.
\param fd file descriptor
\param request request
\param argp argument
\returns result from ioctl
static int xioctl(int fd, int request, void* argp)
int r;
do r = ioctl(fd, request, argp);
while (-1 == r && EINTR == errno);
return r;
process image read
static void imageProcess(const void* p)
unsigned char* src = (unsigned char*)p;
unsigned char* dst = malloc(width*height*3*sizeof(char));
// convert from YUV422 to RGB888
YUV422toRGB888(width,height,src,dst);
void print_array(int *ptr,int len)
// while(len-- > 0)
printf("YUV Data is %x\n",*ptr);
ptr++;
read single frame
static int frameRead(void)
struct v4l2_buffer buf;
#ifdef IO_USERPTR
unsigned int i;
#endif
switch (io)
#ifdef IO_READ
case IO_METHOD_READ:
if (-1 == read (fd, buffers[0].start, buffers[0].length))
switch (errno)
case EAGAIN:
return 0;
case EIO:
// Could ignore EIO, see spec.
// fall through
default:
errno_exit("read");
imageProcess(buffers[0].start);
break;
#endif
#ifdef IO_MMAP
case IO_METHOD_MMAP:
CLEAR (buf);
buf.type = V4L2_BUF_TYPE_VIDEO_CAPTURE;
buf.memory = V4L2_MEMORY_MMAP;
if (-1 == xioctl(fd, VIDIOC_DQBUF, &buf))
switch (errno)
case EAGAIN:
return 0;
case EIO:
// fall through
default:
errno_exit("VIDIOC_DQBUF");
assert (buf.index < n_buffers);
if (-1 == xioctl(fd, VIDIOC_QBUF, &buf))
errno_exit("VIDIOC_QBUF");
av_init_packet(&pkt);
pkt.data = NULL; // packet data will be allocated by the encoder
pkt.size = 0;
fflush(stdout);
avpicture_fill((AVPicture*)frame, NULL, frame->format, frame->width, frame->height);
// print_array(buffers[buf.index].start,buffers[buf.index].length);
frame->pts = num;
num++;
/* encode the image */
ret = avcodec_encode_video2(c, &pkt, frame, &got_output);
if (ret < 0)
fprintf(stderr, "Error encoding frame\n");
exit(1);
if (got_output)
// printf("Write frame %3d (size=%5d)\n", num, pkt.size);
fwrite(pkt.data, 1, pkt.size, fout);
av_free_packet(&pkt);
break;
#endif
#ifdef IO_USERPTR
case IO_METHOD_USERPTR:
CLEAR (buf);
buf.memory = V4L2_MEMORY_USERPTR;
if (-1 == xioctl(fd, VIDIOC_DQBUF, &buf)) {
switch (errno) {
case EAGAIN:
return 0;
case EIO:
// fall through
default:
for (i = 0; i < n_buffers; ++i)
if (buf.m.userptr == (unsigned long) buffers[i].start && buf.length == buffers[i].length)
break;
assert (i < n_buffers);
imageProcess((void *) buf.m.userptr);
break;
#endif
return 1;
mainloop: read frames and process them
static void mainLoop(void)
unsigned int count,codec_id=AV_CODEC_ID_H264;
char *filename="abc.flv";
count = 300;
avcodec_register_all();
printf("Encode video file %s\n", filename);
/* find the mpeg1 video encoder */
codec = avcodec_find_encoder(codec_id);
if (!codec)
fprintf(stderr, "Codec not found\n");
exit(1);
c = avcodec_alloc_context3(codec);
if (!c)
fprintf(stderr, "Could not allocate video codec context\n");
exit(1);
/* put sample parameters */
c->bit_rate = 10000000;
/* resolution must be a multiple of two */
c->width = 640;
c->height = 480;
/* frames per second */
c->time_base = (AVRational){1,25};
c->gop_size = 10; /* emit one intra frame every ten frames */
c->max_b_frames = 1;
c->pix_fmt = AV_PIX_FMT_YUV420P;
if (codec_id == AV_CODEC_ID_H264)
av_opt_set(c->priv_data, "preset", "ultrafast", 0);
/* open it */
if (avcodec_open2(c, codec, NULL) < 0)
fprintf(stderr, "Could not open codec\n");
exit(1);
fout = fopen(filename, "wb");
if (!fout)
fprintf(stderr, "Could not open %s\n", filename);
exit(1);
frame = av_frame_alloc();
if (!frame)
fprintf(stderr, "Could not allocate video frame\n");
exit(1);
frame->format = c->pix_fmt;
frame->width = c->width;
frame->height = c->height;
/* the image can be allocated by any means and av_image_alloc() is
* just the most convenient way if av_malloc() is to be used */
// ret = av_image_alloc(frame->data, frame->linesize, c->width, c->height,c->pix_fmt, 32);
// if (ret < 0)
// fprintf(stderr, "Could not allocate raw picture buffer\n");
// exit(1);
while (count-- > 0)
for (;;)
fd_set fds;
struct timeval tv;
int r;
FD_ZERO(&fds);
FD_SET(fd, &fds);
/* Timeout. */
tv.tv_sec = 10;
tv.tv_usec = 0;
r = select(fd + 1, &fds, NULL, NULL, &tv);
if (-1 == r) {
if (EINTR == errno)
continue;
errno_exit("select");
if (0 == r) {
fprintf (stderr, "select timeout\n");
exit(EXIT_FAILURE);
if (frameRead())
break;
/* EAGAIN - continue select loop. */
for (got_output = 1; got_output; num++)
fflush(stdout);
ret = avcodec_encode_video2(c, &pkt, NULL, &got_output);
if (ret < 0)
exit(1);
if (got_output)
/* add sequence end code to have a real mpeg file */
fwrite(endcode, 1, sizeof(endcode), fout);
fclose(fout);
avcodec_close(c);
av_free(c);
// av_freep(&frame->data[0]);
av_frame_free(&frame);
printf("\n");
stop capturing
static void captureStop(void)
enum v4l2_buf_type type;
switch (io)
#ifdef IO_READ
/* Nothing to do. */
break;
#endif
#ifdef IO_MMAP
#endif
#ifdef IO_USERPTR
#endif
#if defined(IO_MMAP) || defined(IO_USERPTR)
if (-1 == xioctl(fd, VIDIOC_STREAMOFF, &type))
errno_exit("VIDIOC_STREAMOFF");
break;
#endif
start capturing
static void captureStart(void)
unsigned int i;
switch (io) {
#ifdef IO_READ
break;
#endif
#ifdef IO_MMAP
CLEAR (buf);
buf.index = i;
if (-1 == xioctl(fd, VIDIOC_STREAMON, &type))
errno_exit("VIDIOC_STREAMON");
break;
#endif
#ifdef IO_USERPTR
for (i = 0; i < n_buffers; ++i) {
CLEAR (buf);
buf.index = i;
buf.m.userptr = (unsigned long) buffers[i].start;
buf.length = buffers[i].length;
break;
#endif
static void deviceUninit(void)
unsigned int i;
switch (io) {
#ifdef IO_READ
free(buffers[0].start);
break;
#endif
#ifdef IO_MMAP
if (-1 == munmap (buffers[i].start, buffers[i].length))
errno_exit("munmap");
break;
#endif
#ifdef IO_USERPTR
free (buffers[i].start);
break;
#endif
free(buffers);
#ifdef IO_READ
static void readInit(unsigned int buffer_size)
buffers = calloc(1, sizeof(*buffers));
if (!buffers) {
fprintf (stderr, "Out of memory\n");
exit(EXIT_FAILURE);
buffers[0].length = buffer_size;
buffers[0].start = malloc (buffer_size);
if (!buffers[0].start) {
exit(EXIT_FAILURE);
#endif
#ifdef IO_MMAP
static void mmapInit(void)
struct v4l2_requestbuffers req;
CLEAR (req);
req.count = 4;
req.type = V4L2_BUF_TYPE_VIDEO_CAPTURE;
req.memory = V4L2_MEMORY_MMAP;
if (-1 == xioctl(fd, VIDIOC_REQBUFS, &req)) {
if (EINVAL == errno) {
fprintf(stderr, "%s does not support memory mapping\n", deviceName);
exit(EXIT_FAILURE);
} else {
errno_exit("VIDIOC_REQBUFS");
if (req.count < 2) {
fprintf(stderr, "Insufficient buffer memory on %s\n", deviceName);
exit(EXIT_FAILURE);
buffers = calloc(req.count, sizeof(*buffers));
if (!buffers) {
fprintf(stderr, "Out of memory\n");
exit(EXIT_FAILURE);
for (n_buffers = 0; n_buffers < req.count; ++n_buffers) {
CLEAR (buf);
buf.index = n_buffers;
if (-1 == xioctl(fd, VIDIOC_QUERYBUF, &buf))
errno_exit("VIDIOC_QUERYBUF");
buffers[n_buffers].length = buf.length;
buffers[n_buffers].start =
mmap (NULL /* start anywhere */, buf.length, PROT_READ | PROT_WRITE /* required */, MAP_SHARED /* recommended */, fd, buf.m.offset);
if (MAP_FAILED == buffers[n_buffers].start)
errno_exit("mmap");
#endif
#ifdef IO_USERPTR
static void userptrInit(unsigned int buffer_size)
unsigned int page_size;
page_size = getpagesize ();
buffer_size = (buffer_size + page_size - 1) & ~(page_size - 1);
CLEAR(req);
req.count = 4;
req.memory = V4L2_MEMORY_USERPTR;
fprintf(stderr, "%s does not support user pointer i/o\n", deviceName);
exit(EXIT_FAILURE);
} else {
buffers = calloc(4, sizeof (*buffers));
if (!buffers) {
exit(EXIT_FAILURE);
for (n_buffers = 0; n_buffers < 4; ++n_buffers) {
buffers[n_buffers].length = buffer_size;
buffers[n_buffers].start = memalign (/* boundary */ page_size, buffer_size);
if (!buffers[n_buffers].start) {
exit(EXIT_FAILURE);
#endif
initialize device
static void deviceInit(void)
struct v4l2_streamparm stream;
struct v4l2_capability cap;
struct v4l2_cropcap cropcap;
struct v4l2_crop crop;
struct v4l2_format fmt;
unsigned int min;
if (-1 == xioctl(fd, VIDIOC_QUERYCAP, &cap))
fprintf(stderr, "%s is no V4L2 device\n",deviceName);
exit(EXIT_FAILURE);
else
errno_exit("VIDIOC_QUERYCAP");
if (!(cap.capabilities & V4L2_CAP_VIDEO_CAPTURE))
fprintf(stderr, "%s is no video capture device\n",deviceName);
exit(EXIT_FAILURE);
if (-1 == xioctl(fd, VIDIOC_G_PARM, &stream))
// if (EINVAL == errno)
// fprintf(stderr, "%s is no V4L2 device\n",deviceName);
// exit(EXIT_FAILURE);
// else
// errno_exit("VIDIOC_QUERYCAP");
printf("Stream Paramater Type %u\n",stream.type);
printf("Input numerator %d\n",stream.parm.capture.timeperframe.numerator);
printf("Input denominator %d\n",stream.parm.capture.timeperframe.denominator);
printf("output numerator %d\n",stream.parm.output.timeperframe.numerator);
printf("output denominator %d\n",stream.parm.output.timeperframe.denominator);
switch (io) {
#ifdef IO_READ
if (!(cap.capabilities & V4L2_CAP_READWRITE)) {
fprintf(stderr, "%s does not support read i/o\n",deviceName);
exit(EXIT_FAILURE);
break;
#endif
#ifdef IO_MMAP
#endif
#ifdef IO_USERPTR
#endif
if (!(cap.capabilities & V4L2_CAP_STREAMING)) {
fprintf(stderr, "%s does not support streaming i/o\n",deviceName);
exit(EXIT_FAILURE);
break;
#endif
/* Select video input, video standard and tune here. */
CLEAR(cropcap);
cropcap.type = V4L2_BUF_TYPE_VIDEO_CAPTURE;
if (0 == xioctl(fd, VIDIOC_CROPCAP, &cropcap))
crop.type = V4L2_BUF_TYPE_VIDEO_CAPTURE;
crop.c = cropcap.defrect; /* reset to default */
if (-1 == xioctl(fd, VIDIOC_S_CROP, &crop)) {
switch (errno) {
case EINVAL:
/* Cropping not supported. */
break;
default:
/* Errors ignored. */
break;
} else {
CLEAR (fmt);
// v4l2_format
fmt.type = V4L2_BUF_TYPE_VIDEO_CAPTURE;
fmt.fmt.pix.width = width;
fmt.fmt.pix.height = height;
fmt.fmt.pix.pixelformat = V4L2_PIX_FMT_YVU420;
fmt.fmt.pix.field = V4L2_FIELD_INTERLACED;
if (-1 == xioctl(fd, VIDIOC_S_FMT, &fmt))
errno_exit("VIDIOC_S_FMT");
/* Note VIDIOC_S_FMT may change width and height. */
if (width != fmt.fmt.pix.width)
width = fmt.fmt.pix.width;
fprintf(stderr,"Image width set to %i by device %s.\n",width,deviceName);
if (height != fmt.fmt.pix.height)
height = fmt.fmt.pix.height;
fprintf(stderr,"Image height set to %i by device %s.\n",height,deviceName);
/* Buggy driver paranoia. */
min = fmt.fmt.pix.width * 2;
if (fmt.fmt.pix.bytesperline < min)
fmt.fmt.pix.bytesperline = min;
min = fmt.fmt.pix.bytesperline * fmt.fmt.pix.height;
if (fmt.fmt.pix.sizeimage < min)
fmt.fmt.pix.sizeimage = min;
switch (io)
#ifdef IO_READ
readInit(fmt.fmt.pix.sizeimage);
break;
#endif
#ifdef IO_MMAP
mmapInit();
break;
#endif
#ifdef IO_USERPTR
userptrInit(fmt.fmt.pix.sizeimage);
break;
#endif
close device
static void deviceClose(void)
if (-1 == close (fd))
errno_exit("close");
fd = -1;
open device
static void deviceOpen(void)
struct stat st;
// stat file
if (-1 == stat(deviceName, &st))
fprintf(stderr, "Cannot identify '%s': %d, %s\n", deviceName, errno, strerror (errno));
exit(EXIT_FAILURE);
// check if its device
if (!S_ISCHR (st.st_mode))
fprintf(stderr, "%s is no device\n", deviceName);
exit(EXIT_FAILURE);
// open device
fd = open(deviceName, O_RDWR /* required */ | O_NONBLOCK, 0);
// check if opening was successfull
if (-1 == fd) {
fprintf(stderr, "Cannot open '%s': %d, %s\n", deviceName, errno, strerror (errno));
exit(EXIT_FAILURE);
print usage information
static void usage(FILE* fp, int argc, char** argv)
fprintf (fp,
"Usage: %s [options]\n\n"
"Options:\n"
"-d | --device name Video device name [/dev/video0]\n"
"-h | --help Print this message\n"
"-o | --output JPEG output filename\n"
"-q | --quality JPEG quality (0-100)\n"
"-m | --mmap Use memory mapped buffers\n"
"-r | --read Use read() calls\n"
"-u | --userptr Use application allocated buffers\n"
"-W | --width width\n"
"-H | --height height\n"
argv[0]);
static const char short_options [] = "d:ho:q:mruW:H:";
static const struct option
long_options [] = {
{ "device", required_argument, NULL, 'd' },
{ "help", no_argument, NULL, 'h' },
{ "output", required_argument, NULL, 'o' },
{ "quality", required_argument, NULL, 'q' },
{ "mmap", no_argument, NULL, 'm' },
{ "read", no_argument, NULL, 'r' },
{ "userptr", no_argument, NULL, 'u' },
{ "width", required_argument, NULL, 'W' },
{ "height", required_argument, NULL, 'H' },
{ 0, 0, 0, 0 }
int main(int argc, char **argv)
for (;;) {
int index, c = 0;
c = getopt_long(argc, argv, short_options, long_options, &index);
if (-1 == c)
break;
switch (c)
case 0: /* getopt_long() flag */
break;
case 'd':
deviceName = optarg;
break;
case 'h':
// print help
usage (stdout, argc, argv);
exit(EXIT_SUCCESS);
case 'q':
// set jpeg filename
jpegQuality = atoi(optarg);
break;
case 'm':
#ifdef IO_MMAP
#else
fprintf(stderr, "You didn't compile for mmap support.\n");
exit(EXIT_FAILURE);
#endif
break;
case 'r':
#ifdef IO_READ
io = IO_METHOD_READ;
#else
fprintf(stderr, "You didn't compile for read support.\n");
exit(EXIT_FAILURE);
#endif
break;
case 'u':
#ifdef IO_USERPTR
io = IO_METHOD_USERPTR;
#else
fprintf(stderr, "You didn't compile for userptr support.\n");
exit(EXIT_FAILURE);
#endif
break;
case 'W':
// set width
width = atoi(optarg);
break;
case 'H':
// set height
height = atoi(optarg);
break;
default:
usage(stderr, argc, argv);
exit(EXIT_FAILURE);
// open and initialize device
deviceOpen();
deviceInit();
// start capturing
captureStart();
// process frames
mainLoop();
// stop capturing
captureStop();
// close device
deviceUninit();
deviceClose();
exit(EXIT_SUCCESS);
return 0;
It is just for testing, so there are various unused and irrelevant variables in this code.
For Compiling I am running this command
gcc encode.c -o encode -L/usr/local/lib -lavcodec -lavformat -lavutil -lavfilter -lavdevice -lm -lswscale -lswresample -lx264 -lpthread -lz -lfdk-aac -lvpx -lmp3lame -lopus -lvorbis -lvorbisenc -lvorbisfile -ldl -lva -llzma -ltheora -logg
