pal/ntsc issues...please help!
COW Forums : Letters to the COW Team
Priya Patnaik
on Dec 6, 2009 at 5:02:59 pm
Hi everyone,
I'm using the Avid Media Composer to edit a project. Half of the footage I have is on NTSC and the other is PAL ( Everything is DV) I know Avid does not mix PAL and NTSC footage on the same timeline. Question one - Does FInal Cut Pro? If it does, I might consider switching editing softwares
Secondly, if none of them allow me to use PAL and NTSC on the same timeline/project, I would need to convert the footage. Do you have suggestions about how I can convert the footage with the least possible quality loss.
Any suggestions would be much appreciated!
Priya
Chad Brewer
Re: pal/ntsc issues...please help!
on Dec 10, 2009 at 2:16:04 am
Call TeleVersions.
Digital, motion compensated standards conversions (NTSC<->PAL) since 1996.
http://www.televersions.com
312-642-9488
Or, you can render your life away in Final Cut Pro with poor results.
Chad Brewer
