Where does the following question belong?
COW Forums : Letters to the COW Team
Sam Carleton
on Dec 28, 2008 at 11:21:59 pm
I am working on building my editing station. Coming from still photography I understand how important it is to have the correct setup to check color and cropping. So I am trying to determine the correct video I/O card and the correct SD broadcast monitor for my setup.
The 'Art of the Edit' seems more about the process then equipment. 'Windows Hardware & Software' doesn't fit for this isn't computer related. And finally 'Broadcast Design' and 'Broadcast Video' don't seem to fit because this isn't about broadcasting, but equipment.
Where would you recommend I posting a question about the right 'program monitor' setup for my first editing system?
Sam
Stephen Smith
Re: Where does the following question belong?
on Dec 31, 2008 at 9:06:31 pm
I would post it in all of the forums you mentioned. By the way, do you know what software you want to work with? That will really help you decide on what you need.
Stephen Smith
Salt Lake Video
Check out my DVD Money Making Graphics & Effects for Final Cut Studio 2
Fred Jodry
on Jul 15, 2009 at 2:26:55 pm
Typically you ask a Television Engineer or Television Broadcast Engineer about monitors (a.k.a. displays) and cameras themselves. There`s enough to learn though that you`ll likely should learn it on the telephone or in person not make us type until our hands fall off.
Stephen Smith
on Jul 15, 2009 at 2:38:18 pm
Good point, I would respond to that but my fingers have fallen off ;-)
Stephen Smith
Lone Peak Productions
Check out the TV Show Open I did.
Ron Lindeboom
on Jul 15, 2009 at 3:09:16 pm
There are scores of posts about broadcast monitors, etc., and a trip to the COW's search engine is where you should start.
Best regards,
Ron Lindeboom
Creativity is a type of learning process where the teacher and pupil are located in the same individual.
Perfection is achieved, not when there is nothing more to add, but when there is nothing left to take away.
- Antoine de Saint Exupéry
Sam Carleton
on Jul 15, 2009 at 3:17:16 pm
I am the OP...
Just thought I might mention that the OP is like 7 months old, December 28, 2008.
I got my answer a while ago and have since moved on ;)
Thanks folks!
Sam
