 | Cannot add a new services category
on Oct 14, 2008 at 8:21:57 pm |
I would like to add a new service category to your list of services. It would be something like Video -- Archival Footage Restoration. But I get the following error message:
(data_obj) The follwing SQL error occured:
You have an error in your SQL syntax; check the manual that corresponds to your MySQL server version for the right syntax to use near 'function.include'>function.include]: failed to open stream: No such file or ' at line 1
while trying to run this SQL statement:
INSERT INTO `services_categories` (`id`, `category`, `sub_category`, `profile_name`, `count`, `active`) VALUES('', 'Video', 'Archival Footage Restoration', '
Warning: include(/var/www/magazine/htdocs/objs/obj_data.php) [function.include]: failed to open stream: No such file or directory in /var/www/magazine.creativecow.net/htdocs/docs/snips/user_exists.php on line 2
Warning: include() [function.include]: Failed opening '/var/www/magazine/htdocs/objs/obj_data.php' for inclusion (include_path='.:/usr/share/php:/usr/share/pear') in /var/www/magazine.creativecow.net/htdocs/docs/snips/user_exists.php on line 2
Fatal error: Class 'data_obj' not found in /var/www/magazine.creativecow.net/htdocs/docs/snips/user_exists.php on line 3
I have tried using the latest version of Firefox and Safari on my Macbook Pro with osx 10.5
Any suggestions?
Thanks in advance,
Jim Schardt
Pendeen Systems (video restoration services)
 | Re: Cannot add a new services category on Oct 14, 2008 at 10:55:57 pm |
Thanks for the notice - this should be fixed now.
Abraham
